salvagetec
Feb 24, 2018Aspirant
LB1120 SLOW SPEED WITH ATT SIM
This is my 3rd LB1120 modem. I first install was 2 at work off a Sonicwall, for fail over connection. They had slow download speed at first of 5mbps down. Yet my cell phone was getting 28mbps dow...
salvagetec
Feb 26, 2018Aspirant
Yes I update the driver first thing.
JasonN
Mar 01, 2018NETGEAR Employee Retired
Hi salvagetec,
Thank you for your response. So your ISP said you were half a mile away from a "3G" tower. I'm not sure why your modem page would show 4G connection. If you are concerned if your ISP has speed caps on their plans then you should confirm with them to double check. Also if the firmware is up to date, then please perform a factory reset on your LB1120.
Please let me know if this fixed your issue. :]
- Jason N
