salvagetec
Feb 24, 2018Aspirant
LB1120 SLOW SPEED WITH ATT SIM
This is my 3rd LB1120 modem. I first install was 2 at work off a Sonicwall, for fail over connection. They had slow download speed at first of 5mbps down. Yet my cell phone was getting 28mbps dow...
salvagetec
Feb 26, 2018Aspirant
Yes I update the driver first thing.
JasonN
Mar 05, 2018NETGEAR Employee Retired
Hi salvagetec,
I just wanted to check in with you and see if your issue has been fixed.
- Jason N
- salvagetecMar 11, 2018Aspirant
Sorry for the slow response on my dilemma. In Connecticut we’ve had some weather issue that made testing in my freed time un-reliable. So, I’m not feeling 100% percent with my finding yet.
On ATT end I feel like they are doing some bandwidth management on customers. At work on a business account I’m getting solid 34mbps down and a solid 11mbps up, time 2. I have 2-Netgear LB1120 plug into a Sonicwall for fail over for 35 users. I use 1 is for remotes user coming in and the other is for out bound traffic. The same equipment I’m using at home. (Netgear LB1120 and outdoors MINO antenna.) Cell Towers are ¼ mile from both my locations. At home 7-8mbps down and 11mbps up. My phone which has had speed issue during all this is 34mbps down and 11mbps up off the phone screen. Tie to the laptop 8-7mbps down and 11mbps up. So why the slow download down load over the laptop?
I do think my earlier issue was having and other here have posted about ATT marking my modem as 4g-lte device. The second is Windows 10 network setting on my test laptop had been set to Public in the network setting. That mad the Windows firewall and anti-virus screw up my download test. I also try upgrade my wifi adapter to an “AC” wireless to match my new modem. My new ASUS router doesn’t have a MTU setting I can re-set for the cellular connection. The Sonicwall at work does and is set to 1420 bytes.
At this point is cell tower issue, laptop connection or Router MTU setting issue?
