importdezign
Jan 15, 2018Aspirant
LB1120 T-Mobile SLOW speeds
Hello, recently purchased the netgear lb1121 for T mobile. I have the 6gig data plan and will be using this device with the google wifi router to spread internet throught the house. The speeds ...
imelectronic
Jan 27, 2018Aspirant
Did you find a solution?
Did you try bridged mode?
You may need to add in a router running a custom firmware that allows the TTL value to be modified. Asuswrt Merlin has this.
