importdezign
Jan 15, 2018Aspirant
LB1120 T-Mobile SLOW speeds
Hello, recently purchased the netgear lb1121 for T mobile. I have the 6gig data plan and will be using this device with the google wifi router to spread internet throught the house. The speeds ...
countrywidewifi
Feb 11, 2018Tutor
is the phone and the Lb1120 on the same band? i've seen mine be next to each other (phone & modem) and be on different bands as i can pick up all 3 and there is a large speed difference between them. wish they would put a band selection option on the modem.
- importdezignFeb 11, 2018AspirantI have not check that yet. Can you change the band on the phone?
- countrywidewifiFeb 11, 2018Tutor
no i use an app called "cellmapper" it will display your current band on the phone and then for the modem you can see it once you log in settings/mobile/status
- importdezignFeb 11, 2018AspirantThanks I will test this out. I guess you have to keep reconnect to get onto the same band?
