importdezign
Jan 15, 2018Aspirant
LB1120 T-Mobile SLOW speeds
Hello, recently purchased the netgear lb1121 for T mobile. I have the 6gig data plan and will be using this device with the google wifi router to spread internet throught the house. The speeds ...
importdezign
Feb 11, 2018Aspirant
I have not check that yet. Can you change the band on the phone?
countrywidewifi
Feb 11, 2018Tutor
no i use an app called "cellmapper" it will display your current band on the phone and then for the modem you can see it once you log in settings/mobile/status
- importdezignFeb 11, 2018AspirantThanks I will test this out. I guess you have to keep reconnect to get onto the same band?
- countrywidewifiFeb 11, 2018Tutor
no its random. been told its all on the carrier as to what band it picks based on congestion, demand, etc.... now i have played with a directional antenna and if i point it east they will all stay on band 4 as the tower in that direction only has band 4
