aprwx
Aug 14, 2018Aspirant
LB1121 – 4G LTE Modem Port Forwarding
I've spent several hours trying to get port forwarding set up using the LB1121 – 4G LTE Modem with PoE connected to an Asus router.
I am expecting to connect the modem to the router and have th...
nathankferguson
Dec 19, 2018Initiate
I've been trying to do almost the "exact" same thing.
In MY case, I am using an ATT lte sim card as my ISP, and therein lies the culprit. For me, ATT will not give out a static IP specifically to you so the ports being forwarded are stopping at ATT's discretion in how they share multiple IP addresses with multiple customers to help with IPv4 costs (although supposedly trying to to move to IPv6..who knows).
Because of this, a lot of my servers will claim I have a "double-nat" setup, and cannot see themselves outside the local network.
If you've learned anything past this, please share!
Nathan
aprwx
Dec 19, 2018Aspirant
That's interesting, I didn't realize that they could share IPs among different customers. Perhaps thats the issue I'm having with my T-Mobile setup.
I haven't resolved the issue, instead I came up with an acceptable solution for me. I install TeamViewer which allows encrypted access over port 80 (I assume), and then from there I can control a Raspberry Pi that I have running it. From there I am able to do whatever I need. via command line, browser or even php scripts on the Pi.
