MohitSoni
Apr 28, 2017Follower
LB1121 PoE Setup
LB1121 Air card does not power up with just Ethernet Cable plugged in to the router (R8000), is there any step that i am missing in settings page for the air card? It does start with the power adapte...
DarrenM
May 02, 2017Sr. NETGEAR Moderator
Hello Mohitsoni
The R8000 does not not have POE so it is not sending power to the modem.
DarrenM
