Giebat's avatar
Giebat
LB2120 - Using both ethernet ports for LAN?
I have a business need to have a portable 4G router but I require 2 ethernet ports (LAN) that both have DHCP and can communicate between them as well as connect to internet. Looking at LB2120 but can't see a way to turn the WAN port to a LAN port. Is it possible?
    • Giebat's avatar
      Giebat
      The thing is that this is supposed to be used as a mobile demo setup and I really want to avoid the extra hardware. So a switch is just an option if I can't find a 4G modem with 2 ethernet ports.
      • JasonN's avatar
        JasonN
        NETGEAR Employee Retired
        Hi Giebat,
        I agree with TheEther on this and that the Ethernet switch would be your best resolution on this. :]
        - Jason N
