mgandalf
Oct 29, 2017Tutor
LB2120 and Ubiquiti EdgeMax - LAN resetting
I have an LB2120 running the latest firmware connected to a Ubiquiti EdgeMax router running also the latest (1.9.7). When I place the LB2120 in bridge mode, the EdgeMax gets an IP and sets the defaul...
mgandalf
Oct 31, 2017Tutor
Anyone have any thoughts?
Thanks, Mark.
JamesGL
Nov 02, 2017NETGEAR Employee Retired
Hi mgandalf,
You have mentioned that issue did not occur when you have downgraded to previous firmware of your EdgeMax and it only happens with the latest firmware. Have you checked with Ubiquiti if there is a known issue with the latest firmware?
- mgandalfNov 03, 2017Tutor
Yes, I have the question out to them as well.
- Mark.
- msausenNov 03, 2017Tutor
I'm having the exact same problem with a USG. Lan comes up, the connection is stable in bridge mode but as soon as the Netgear get's under a load (about 30 seconds) the power light on the 1120 blinks amber and the LAN connection resets. Newest firmware on the 1120 and current on the USG.
Mark, do you have a link to a Ubiquiti thread or a case number I can reference if I call them?
- mgandalfNov 06, 2017Tutor
My thread is more related to the issue of a default outside of the /32 the modem gives me for an IP, which started me down the road of upgrading the Ubiquiti and Netgear firmware.
I have done a bit more investigation, however. I tried hard-setting the link speed all the way from 10/half to 100/full with no difference. I also placed a 1gig switch inbetween the modem and the router - no change. This doesn't seem to be a problem on the Ubuquiti end in my opinion. The modem's LAN interface shouldn't be disconnecting/resetting like it does.
- Mark.
