jeff98363
Jan 09, 2019Follower
LB2120 Failover Time - How long should it take to switch?
My system is set up using LB2120 in Bridge mode between my cable modem and my router. It's configured to switch to 4G backup if my cable modem is disrupted. I conducted quite a few tests disconnect...
dc5dd
Jan 18, 2019Tutor
Are you browsing the internet when you disconnect? When I do a test it takes about 30 seconds to a minute.
- jeff92123Jan 18, 2019Aspirant
Yes I have the internet browser open during tests to check for internet connectivity. At the same time I'm watching the power button indicator on the LB2120 which indicates when cellular connectivity begins. I'm also watching the Netgear dashboard page.
