ryannelson
Aug 31, 2019Tutor
LB2120 Feature request - ping test fail over setting
Hello,
The LB2120 is a great device. It is able to do almost everything I want. However I wish I had a setting where I could configure how often the ping test for detecting failing over happens. Meaning the time interval for when the ping test happens and either fails or successeds to determine if the device should fail over from the landline connection to the celluar connection.
Is this feature available and I'm not aware of where it is?
If its not available can the be added to a firemware update.
Thank you,
Ryan
- Blanca_ONETGEAR Employee Retired
Hi ryannelson
Welcome to NETGEAR Community!
We recommend posting your suggestion on our Idea Exchange board. Our Product Managers review the board for great ideas to be implemented in future releases. Link is https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
Done.
Thank you,
Ryan
