agdodge4x4
Jan 27, 2018Luminary
Lb2120 firmware update failure
It won't update. Reset it a bunch. Rebooted. Doesn't work. How do you get this thing to update? Testing this device since my mr1100 has been an absolute nightmare hell. Any easy fix?
- Jan 28, 2018
Solved. You have to be in BRIDGE MODE to update this router.
This kind of thing needs to be in the manual, guys. You can't expect everyone to figure this out for themselves. :smileymad:
JasonN
Feb 06, 2018NETGEAR Employee Retired
Hi Everyone,
Does anyone still have the issue of updating the firmware? Please PM me and I will work with you. Thank you. :]
- Jason N
Brookeville
Feb 06, 2018Aspirant
Jason;
I am ready to purchase a Netgear LB-1120. My application will require proper functionality of the bridge mode feature. I have been following the realted blog/support/Netgear forum threads for several weeks. There have obviously been some firmware upgrades that correct the problems of bridge mode operation which was evidently problematic in the earlier versions of the LB-1120 shipments. TWO related questions;
1.What is the current version of firmware that is shipping with the LB-1120?
2.Is that version available on new shipments as of a particular date i.e., October ##, 2017? or some other date and how do I I.D. the proper serial sequence, etc?. BOTTOM LINE: If possible I would like to avoid having to perform a software update on a new unit if polssible! Please advise. THANKS, Stan
