agdodge4x4
Jan 27, 2018Luminary
Lb2120 firmware update failure
It won't update. Reset it a bunch. Rebooted. Doesn't work. How do you get this thing to update? Testing this device since my mr1100 has been an absolute nightmare hell. Any easy fix?
- Jan 28, 2018
Solved. You have to be in BRIDGE MODE to update this router.
This kind of thing needs to be in the manual, guys. You can't expect everyone to figure this out for themselves. :smileymad:
holsteinson
Feb 06, 2018Tutor
Tried today in bridge and router and both cases the firmware update stopped at 52% on my LB2120
JasonN
Feb 07, 2018NETGEAR Employee Retired
Hi Brookeville,
As for the LB1120. The firmware depends on when the device was manufactured. The LB1120 will notify you when there is a new firmware to upgrade to. You have the choice of approving or denying it the first few times. Eventually it will just upgrade to the new firmware on its own. As for the security updates, those will auto update.
Hi Holsteinson,
I will PM you now to collect some information from you.
- Jason N
