FinnborgBraga
Oct 27, 2017Aspirant
LB2120 flashing green power light
Hi all, I have just bought a LB2120. When the 'wireline' is disconnected, the power light flashes green, which is not documented in the user manual. What does this mean? It is connecting to the i...
FinnborgBraga
Oct 31, 2017Aspirant
Yes.
By observation, the flashing green is the modem showing that it has fallen over to 4G, with steady green showing that the 'wireline' is working and thus the modem has not fallen over to 4G.
Perhaps not a fault with the modem itself, more a significant ommission from the documentation. Perhaps a feature introduced with a 'recent' firmware update, and Netgear haven't bothered to update the documentation?
DarrenM
Nov 15, 2017Sr. NETGEAR Moderator
A blinking Green power LED means that the LTE modem is accessing Internet from cellular side instead of wired WAN side (failed over to wireless Internet).
DarrenM
