srekik
Feb 07, 2018Aspirant
LB2120 frequently hungs
Hi Nearly everyday the modem stops working. And I have to power it off and on to work again. When the problem occurs : Power Led : solid amber Lan led : solid green Signal : bar 1 and 2 are s...
countrywidewifi
Feb 11, 2018Tutor
only seen an amber light on mine once but the towers went down that day been using about 3 months.
- srekikFeb 11, 2018Aspirant
Hi
Thanks for your reply.
In my case the issue happens nearly everyday.
In fact I use the LB2120 to send only a very short email once per a day at midnight.
May be I need to send periodicaly a keep alive message once per hour to check if the issue disaapears or occurs at a certain hour.
Best Regards
