Azerty32
Aug 04, 2021Initiate
[LB2120] How to enter MCC and MNC for APN configuration?
Hello, I have a LB2120 4G router and I have some difficulties to configure the APN - usage in France. My mobile provider is a MVNO called Symamobile. I am supposed to enter a MCC and MNC to configur...
michaelkenward
Aug 05, 2021Guru - Experienced User
Azerty32 wrote:
Hello,
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your LB2120 hardware. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Azerty32Aug 06, 2021Initiate
michaelkenward wrote:
Azerty32 wrote:Hello,
I have a LB2120 4G router and I have some difficulties to configure the APN - usage in France.You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your LB2120 hardware. That's probably here:
Support | NETGEAR
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.Hello,
Thank you for the tips.
I already checked the manual and could not find the solution. I hope someone could help me otherwise I will choose another device (or mobile provider).
