srekik
Feb 08, 2018Aspirant
LB2120 LTE Plantage
Bonjour J'ai constaté un plantage régulier de la box : presque tous les jours. Il faut la débrancher et rebrancher au secteur pour la redémarrer. Quand elle plante : Led Power : allumé en rouge ...
JasonN
Feb 14, 2018NETGEAR Employee Retired
Hi srekik,
Is your device up to the most current firmware? Have you done a factory reset on it?
Your LEDs for the LAN and Signal Strength seems normal except your Power LED. The LED for your power should only be between the colors of Green & Amber.
Can you confirm if it is red or amber? Thank you :]
- Jason N
