srekik
Feb 08, 2018Aspirant
LB2120 LTE Plantage
Bonjour J'ai constaté un plantage régulier de la box : presque tous les jours. Il faut la débrancher et rebrancher au secteur pour la redémarrer. Quand elle plante : Led Power : allumé en rouge ...
JasonN
Feb 20, 2018NETGEAR Employee Retired
Hi srekik,
I just wanted to check up on you and see if you're still having the issue. Please let me know :]
- Jason N
srekik
Feb 20, 2018Aspirant
Hi Jason I haven't take care if its is solid RED or solid Amber. But it seems rather Amber see photo below. In fact the router is connected to a PC on LAN1. The PC sends once per a day a short sms about the state of connected devices to local LAN. The router is installed in a remote site far from my office. No antenna was connected to the router. For the moment I replaced the router by a D-LINK DWR921 with integrated 4G antennas. I have succeeded now in my office to update firmware but remote update trials. have failed. I will make new tests as soon as possible. Mean while I added the ability to send a new empty sms every hour as a keep alive signal to better control the router working status. For the moment I have no problem with DWR921. Best Regards +33 6 27 76 73 36 Samir REKIK Aris Technologies
- JasonNFeb 21, 2018NETGEAR Employee Retired
Hi srekik,
Thank you for your response! Please update me when you have found out. :]
- Jason N
