dottodotto
Jun 28, 2022Follower
lb2120 modem
I have an lb2120 connected via google nest home my spped with one user is 70megabit but with 5 users or more speed per user drops to less than 1 megabit is this my netgear moden or my google nest mesh systems fault ??? ideas please
- Elmer894Aspirant
Is there any update regarding this malware? Please someone help me. I think you should check out site name support site hope this helps! I am facing the same issue someone help me out. GoMedicare Cost
The lb2120 has its own integrated router function because it can act as failover for a primary connection from a dsl/fibre/cable connection.
since it has its own router and so does googles, it causes a double nat.
did you try putting the lb2120 in bridge mode? (per page 26 on the manual)
