tplustplus
May 05, 2018Tutor
LB2120: no automatic re-connect
Hello,
frequently (every 24 - 30 hours) my LB2120 is losing connection (amber LED) but won't reconnect automatically although I set in the menu "reconnect automatically, always". It's set to br...
Computman
Oct 14, 2018Guide
Same issue here
This equipement was bought to failover but it is not reliable enough
Any firmware update of beta version available ?
- Blanca_OOct 14, 2018NETGEAR Employee Retired
- tplustplusOct 16, 2018Tutor
Are there any updates?
I ended up breaking the power supply of the device by a timer every night in order to have it available at least the next day.
- ComputmanOct 19, 2018Guide
Blanca_O wrote:
I have sent you a message. Please check your inbox.
Blanca
Community Team
I have sent you my answerThx
- sktmNov 03, 2018Guide
I have the same issue with an LB2120-100UKS despite having auto reconnect enabled, it only reconnects with a power cycle.
It does this every couple of days despite excellent mobile signal and I know the signal is good as I have alarm singalling equipment with a SIM from the same provider that stays connected with no issues (it logs even very short loss of signal and logs are clean).
Is there any firmware to fix this?
- Piet2440Oct 28, 2018Aspirant
Hello, can you help me too ?
I have the same problem... 3 modems in the field. Fall out during the night.
- ComputmanOct 29, 2018Guide
Hi,
I have opened a case. They are investigating
Open a case at the support as they will know that this issue is not isolated and is not hardware but software
