tplustplus
May 05, 2018Tutor
LB2120: no automatic re-connect
Hello,
frequently (every 24 - 30 hours) my LB2120 is losing connection (amber LED) but won't reconnect automatically although I set in the menu "reconnect automatically, always". It's set to br...
Blanca_O
Oct 14, 2018NETGEAR Employee Retired
tplustplus
Oct 16, 2018Tutor
Are there any updates?
I ended up breaking the power supply of the device by a timer every night in order to have it available at least the next day.
