tplustplus
May 05, 2018Tutor
LB2120: no automatic re-connect
Hello,
frequently (every 24 - 30 hours) my LB2120 is losing connection (amber LED) but won't reconnect automatically although I set in the menu "reconnect automatically, always". It's set to br...
SteveBaier
Feb 04, 2019Aspirant
Hi,
Same problem here.
Is there any solution in the meantime, I mean besides the mentioned workarounds.
Thanks
Steve
- JetroFeb 05, 2019Guide
Hi guys,
It's more than a month since the Huawei modem is connected and has never lost the connection: i confirm LB2120 has several problem!
- AIB-CEOFeb 05, 2019Initiate
I have given up with this device. It was supplied by Amazon and although the return window had closed, I argued that the product is not fit for purpose and they agreed to a refund.
We now have an integrated Draytek Vigo 2860LB router with 4G failover - this works seamlessly and without the need for constant reboot and checking that the failover 4G is connected.
Given the amount of legacy Netgear products we have (managed and unmanaged switches that were built to a high standard) we are extremely disappointed with the LB2120 device. We will now be looking for different suppliers as our faith in Netgear has been undermined by this episode.
