tplustplus
May 05, 2018Tutor
LB2120: no automatic re-connect
Hello,
frequently (every 24 - 30 hours) my LB2120 is losing connection (amber LED) but won't reconnect automatically although I set in the menu "reconnect automatically, always". It's set to br...
rramstad
Aug 23, 2019Guide
I am now deeply offended.
I made a post here a few days ago detailing my experience.
That post has been deleted and no one told me that it was deleted or why.
In a nutshell, I requested beta participation, and then had the reconnection problem again. I asked about the beta firmware and was told it was pushed to my device 10 days prior. I explained that I had the problem again and asked them what the firmware revision was that I should have. They responded and gave me the current production firmware and said that my firmware should be a different identifier. I wrote back and said it wasn't, that I still had the production firmware. They said they'd look into it.
Shortly after that I made a post here recommending that folks who had asked to be in the beta consider contacting support and asking them about the status, especially if they were still running the stock firmware version.
That post has mysteriously disappeared from this forum. No idea why.
It's now been almost a week, and I've had no further updates. My device just crapped out again about an hour ago with the same symptoms -- once it loses connection to broadband, it will never reconnect successfully, without me manually unplugging the Ethernet from the device, waiting 10 seconds, and plugging it back in. It can't detect that the broadband is fine without being physically disconnected from the broadband first.
rramstad
Sep 19, 2019Guide
Hi, I am increasingly frustrated. My device still shows the same firmware revision and it appears that Netgear has never been able to push the beta firmware to me. I have heard nothing back from anyone at Netgear in many weeks, either through the regular support channels or through this forum. It's ridiculous.
