lwells
Dec 30, 2017Aspirant
LB2120 not booting / unknown LED pattern
Hi I have an issue with an LB2120 LTE modem (LB2120-100AUS - H/W 1.0(0701)). Once switched on, the power LED comes on for a moment or two, and then the modem displays the following LED sequen...
Stephen12345
Apr 14, 2018Aspirant
Did you resolve this problem? My modem is doing the same thing.
lwells
I simply ended up having to replace the modem, which was unfortunate given I couldn't locate the receipt and recieved no responses or assistance from Netgear.
- BowloApr 17, 2018Aspirant
Same. Worked fine for about a month and went into this mode for no apparent reason.
LB2120-100AUS
