zbiles
Mar 11, 2018Aspirant
LB2120 Providing Private IP to device connected in bridge mode
My LB2120 is exhibiting some odd behavior. When I set it to bridge mode, it's supposed to pass the WAN IP to the connected device. It doesn't seem to be doing this. Instead, it provides a private 10....
zbiles
Mar 21, 2018Aspirant
I haven't had a chance to try this yet. Once I do, I will update with results.
-Zach
JasonN
Mar 26, 2018NETGEAR Employee Retired
Hi zbiles,
I'm checking in again and see if you had a chance to perform the steps I've have given you.
Please let me know. :]
- Jason N
- zbilesMar 26, 2018Aspirant
Firmware is showing as up-to-date and I tried a factory reset. Still receiving a private 10.193.X.X address on my second router when in bridge mode.
Thanks,
Zach
- JasonNMar 27, 2018NETGEAR Employee Retired
Hi zbiles,
I found a semi similar setup from another user and wanted to see if this setup would work for you.
Please let me know if it helps your issue. :]
- Jason N
- JasonNMar 30, 2018NETGEAR Employee Retired
Hi zbiles,
I wanted to check in and see if this user's setup works for you.
- Jason N
- zbilesMar 31, 2018AspirantThis did not work. Though I found out it doesn't appear to be a problem with the Netgear equipment. I found out that AT&T does not give public IP addresses to consumer devices and I have no way to get one. So that's why I'm getting a private IP.
