superjet
Jul 27, 2017Star
LB2120 really flaky connection, can output to syslog or no?
lb2120 running in bridge mode with AT&T service. Every so often (seems random) my router will report the connection to be down, then 2 minutes or so later it comes back up. I would like to be able t...
pnc-arlo
Oct 18, 2017Aspirant
Were you able to troubleshoot your flaky connection? I was seeing the same issue. The only time that I haven't seen dropping and reconnecting is when I:
- Put the LB2120 in bridged mode
- Connect the LB2120 WAN port to a router LAN port
- Connect the LB2120 LAN port to a device (in my case a SmartThings hub)
It's not my ideal solution, but, for now, it works as a cellular backup to just my SmartThings hub. I would rather the LB2120 be a redundant connection for my entire network, but with it dropping, it makes the router/network unstable.
Hopefully someone has found a solution and will respond.
- superjetDec 01, 2017Star
I just put it in router mode and gave up on getting a good vpn connection.
