superjet
Jul 27, 2017Star
LB2120 really flaky connection, can output to syslog or no?
lb2120 running in bridge mode with AT&T service. Every so often (seems random) my router will report the connection to be down, then 2 minutes or so later it comes back up. I would like to be able t...
Retired_Member
Feb 02, 2018I have the same problem. I think the connection of the provider goes sometimes down for 3 seconds and the LB2120 switches to cellular.
There should be an option to tell the device how long to wait before making the failover. Otherwise I get several message per day per downtime from the provider.
Is there a place where we can suggest new functions?
