AaronLTek
Jan 24, 2019Guide
LB2120 Setup Info for Fail Over situations?
Searched all over, cant find proper setup instructions to use this as a fail over for a down cable internet connection?
Does anyone have experience with this? I've already wasted $70 in data b...
AaronLTek
Jan 24, 2019Guide
UPDATE...
Attached screenshots showing configs of ASUS & LB2120
I think I'm close... I put the LB2120 in Bridge mode with ASUS Wifi Router (also the firewall) in the LB2120's DMZ (LB2120 has default IP 192.168.5.1 :: ASUS has static IP of 192.168.5.2)
Problem is, the LB2120 is blocking incomiming communications and/or ports. With just my ASUS router running (LB2120 not connected) everything works as expected.
It looks like the LB2120 is not passing external (WAN) communications to the ASUS. When I use my mobile apps that request data/comms from the Internet -- connection is initiated from teh Internet, it never reaches the apps inside my network. When the internal apps use a cloud proxy (Hikvision, Samsung, etc) where the internal apps initiate the comms (from inside my network)... the mobile apps work fine.
Thus apps that go directly to IP:port (or DDNS:port) do not ever connect. I verified that DDNS is working properly, correct IP.
Anyone have any ideas?
thx for the help
