trousers
Aug 08, 2018Tutor
LB2120 won't auto-connect after an outage
Hello I have a LB2120 providing LTE backup for my primary internet line. It is connected in failover mode to a pfSense firewall as a standby interface. Signal strength shows as 2 or 3 bars, and pfSen...
Jttgg
Aug 21, 2018Tutor
Same experience.
A scheduled curl script should solve it, sending the reconnect request.
If you know curl, please try and share :-)
- trousersAug 21, 2018Tutor
You shouldn't have to mess around with scripting just to get a product to do what it was designed to do - and clearly doesn't. I've had the same problem with 2 of these units - and the best solution is to throw them away and buy something which performs as advertised. Since I've moved to the other vendor's product I mentioned in my earlier post I haven't had a single issue. Good luck!
- JttggAug 21, 2018TutorAgreed.
