trousers
Aug 08, 2018Tutor
LB2120 won't auto-connect after an outage
Hello I have a LB2120 providing LTE backup for my primary internet line. It is connected in failover mode to a pfSense firewall as a standby interface. Signal strength shows as 2 or 3 bars, and pfSen...
trousers
Aug 14, 2018Tutor
I've solved the problem myself - and now have a reliable failover connection. The steps I took were:
1) Disconnect Netgear LB2120
2) Throw in trash can
3) Replace with Yeacomm 3G 4G LTE Router
4) problem solved.
I seriously wouldn't recommend the LB2120 - wish I had purchased the Yeacomm in the first place and not bothered with domestic grade products. Could have saved some money as well.
Dave
cynthih
Nov 08, 2018Aspirant
What is the specific model? I found the "Outdoor" model. The Yifan website also lists an "indoor" model and some other models.
- trousersNov 09, 2018Tutor
I now use these - very reliable - you can get them on Amazon:
Yeacomm Outdoor 4G CPE Router, 3G 4G LTE Router with SIM Card Slot,150Mbps CAT4 Mobile Router, Without Wifi (4G ROUTER)
- AaronLTekJan 01, 2019Guide
Installed a brand new Netgear LB2120 yesterday.I already hate this thing. Calling Netgear support tomorrow - I'm pissed.
Issue...
1. At 11:30pm (a few hours after it was up and running for the first time) it failed to 4G -- even though Xfinity confirmed there was no outage.
2. Problem -- it never reconnected to the cable modem; costing me $70 in 4G data charges (12GB in 4G in about 10 hrs)
thx!Have you tested it - extensively?Installed a brand new Netgear LB2120 yesterday. At 11:30pm it decided to fail to 4G even though I confirmed with Xfinity, there ws no outage. Problem was... it never reconnected to the cable modem costing me $70 in 4G data charges (12GB in 4G in about 10 hrs)... calling Netgear tomorrow, I'm pretty pissed.thx!- AaronLTekJan 10, 2019Guide
guys, hows the Yeacomm 3G 4G LTE Router treating you? I simply need it to be a failover for my cable internet.
Does it provide decent options? I liked how the NetGear will send you TXT & Emails and also set alert for data usage.
thx!
