trousers
Aug 08, 2018Tutor
LB2120 won't auto-connect after an outage
Hello I have a LB2120 providing LTE backup for my primary internet line. It is connected in failover mode to a pfSense firewall as a standby interface. Signal strength shows as 2 or 3 bars, and pfSen...
cynthih
Nov 08, 2018Aspirant
> Yeacomm 3G 4G LTE Router
What is the specific model? I found the "Outdoor" model. The Yifan website also lists an "indoor" model and some other models.
trousers
Nov 09, 2018Tutor
I now use these - very reliable - you can get them on Amazon:
Yeacomm Outdoor 4G CPE Router, 3G 4G LTE Router with SIM Card Slot,150Mbps CAT4 Mobile Router, Without Wifi (4G ROUTER)
- AaronLTekJan 01, 2019Guide
Installed a brand new Netgear LB2120 yesterday.I already hate this thing. Calling Netgear support tomorrow - I'm pissed.
Issue...
1. At 11:30pm (a few hours after it was up and running for the first time) it failed to 4G -- even though Xfinity confirmed there was no outage.
2. Problem -- it never reconnected to the cable modem; costing me $70 in 4G data charges (12GB in 4G in about 10 hrs)
thx!Have you tested it - extensively?Installed a brand new Netgear LB2120 yesterday. At 11:30pm it decided to fail to 4G even though I confirmed with Xfinity, there ws no outage. Problem was... it never reconnected to the cable modem costing me $70 in 4G data charges (12GB in 4G in about 10 hrs)... calling Netgear tomorrow, I'm pretty pissed.thx!- AaronLTekJan 10, 2019Guide
guys, hows the Yeacomm 3G 4G LTE Router treating you? I simply need it to be a failover for my cable internet.
Does it provide decent options? I liked how the NetGear will send you TXT & Emails and also set alert for data usage.
thx!
