2DogsMonty's avatar
2DogsMonty
Leaving MR2100 connected to power
Would it harm the battery if I left my MR2100 permanently connected to mains power?  Cheers, Bill
  • michaelkenward's avatar
    michaelkenward
    That's a mobile modem router.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi 2DogsMonty ,
    It wont harm the battery if it is on permanent charge.  However, we do recommend using it without the battery if you intend to have it on permanent charge.
    Arodi
