MitchBVI
May 09, 2018Aspirant
LED Lights out GS105
ProSafe GS105
All the LED lifghts excep the one showing power are out. None of the devices connected to the switch are working. Interestingly when one device stopped working I switched the ethe...
JasonN
May 15, 2018NETGEAR Employee Retired
Hi MitchBVI,
Thank you for posting in the community. I wanted to check have you tried using a different power supply on the device?
Please let me know. :]
- Jason N
- MitchBVIMay 16, 2018Aspirant
D you mean a diferent plug not sure if Ihave another NG block
- JasonNMay 21, 2018NETGEAR Employee Retired
Hi MitchBVI,
Thank you for your response. Yes, I meant a different plug as in another power cable. This can tell us if its the cable or the actual device.
- Jason N
