santimaster2000
Nov 30, 2021Follower
LM1200 4G LTE Modem Firmware won't update
I purchased an LM1200 LTE Modem/Router to serve as a fallback connection for my computer, the WAN feature seems to require a firmware update, I've tried updating through the web UI, but it keeps giving me an update error, did several resets and 2 factory resets, still, no dice.
- ThomasWheelerAspirant
Same here spent a few hours with support they are no help. I was asking for a link to download the firmware and see if we can update it that way.
- JohnPengNETGEAR Expert
I will post a public link soon to the FW upgrade release. Please check your private message first,
Thanks
John
- simnettechAspirant
Hi, just wondering if you can still post that link. Still seeing that LAN port issue with multiple LM1200 modems and hoping the firmware update will fix the issue.
Thanks,
SimNet Tech
I also need a copy of the firmware if someone is able to send it to me.
