Lsmith94
Feb 13, 2023Aspirant
LM1200 connecting but no internet
I purchased a LM1200 in August 2022 to use when our regular internet provider was down as I work from home. Well it is down again and I went to connect today and I cannot get any type of connection a...
Lsmith94
Apparently the modem. ATT support said everything was fine on their end as far as the SIM.
The modem would have been in a box in my basement at the time. I’ve never reported it stolen or has it been outside of my house so I don’t know why that would be there.
JohnPeng
Feb 15, 2023NETGEAR Expert
You can try to get a AT&T BYOD plan. This has been confirmed working with LM1200. The device is AT&T certified, which really means the device can work with AT&T BYOD plan. If you are using other AT&T plans, it is not guaranteed it will work with the device. If AT&T changes something on their side on the plan, the data service may be blocked.
Thanks
John
