shawnsbrain66's avatar
Nov 02, 2022
LM1200 doesn't see/detect SIM card
I have a new LM1200.
I have a known good Verizon SIM card (it works if I plug it into a phone).
When I put it into the LM1200, it says "SIM NOT DETECTED".
I've tried putting the card in different ways but it just doesn't detect the SIM.
It's a pretty straight forward device so I'm assuming it's just defective, but is there anything else I can try?
4G LTE Modem (LM1200) #SIM
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    There is only one way you can insert the SIM in the slot. You will feel the click when it is inserted properly.
    I suggest you to request a replacement if it is confirmed the device really can't detect the SIM card properly.
    Thanks
    John
