ChrisMendes
Oct 11, 2022Aspirant
LM1200 frequently loses WAN connection
I have an LM1200 between my broadband internet connection and Netgear Orbi. I intended to use the LM1200 as a 4G fallback for my internet. However, it looks like the LM1200 frequently drops the WAN ...
ChrisMendes
Oct 13, 2022Aspirant
Hi John
LM1200 firmware version is:
Firmware Version: EC25EUGAR07A01M4G App Version: NTG9X07W_20.06.09.00 Web App Version: LM1200-HDATA_03.03.103.201 Hardware Version: 1.0
Netgear Orbi firmware is: V2.7.3.22
ISP is Vodafone but I am connecting directly to the NBN modem. This works fine when the Orbi is connected to teh NBN modem.
Regards
Chris
JohnPeng
Oct 13, 2022NETGEAR Expert
Thanks for the confirmation. LM1200 doesn't work well with certain modems. We have customers reported the similar issues with cable modems that LM1200 can't detect the data connection on the cable modem and set up the data connection properly. We will investigate it
When you say Orbi can connect to the NBN modem, do you need to make certain configurations on Orbi app or Orbi GUI?
To do a quick test, you can set up the devices in the following way and see whether LM1200 WAN connection can stay stably.
NBN Cable Modem -> Orbi LAN Port -> LM1200 WAN Port -> LM1200 LAN port -> Your laptop.
Thanks
John
ChrisMendes wrote:
Hi JohnLM1200 firmware version is:Firmware Version: EC25EUGAR07A01M4G App Version: NTG9X07W_20.06.09.00 Web App Version: LM1200-HDATA_03.03.103.201 Hardware Version: 1.0Netgear Orbi firmware is: V2.7.3.22ISP is Vodafone but I am connecting directly to the NBN modem. This works fine when the Orbi is connected to teh NBN modem.Regards
Chris
