schmittalvin's avatar
schmittalvin
LM1200 imei number and gen quest
I need the imei number before I can buy in order to know if it works with TING. also I will be running it on DC so if it is on (powered on) all the time will I be charged anything or can I leave it on all the time?
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    You can use the device's IMEI TAC code: 25631611 to check whether the device is compatible or not.
    The device dooesn't use battery. It needs to be powered on with Power Adaptor.
    Thanks
    • schmittalvin's avatar
      schmittalvin
      I am an electrical engineer with over 50 years experience so I know how to power the device with a car battery even if i have to conver to 60 hz 120vac.
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        It will not use extra data if you keep it on 24/7 if you don't have device connecting to it.
        Thanks
