JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
JinTu
Sep 01, 2021Star
The end of August has come and gone with no indication of new firmware being available.
JohnPeng are there any revised projections on when the LM1200 firmware update will be released?
- JohnPengSep 02, 2021NETGEAR Expert
The latest LM1200 release has been posted online. If your device's IMEI is ending with 0, 1, 2, 3 and 4, it can be upgraded now.
Please do a factory reset after upgrage and clear browser cache to start over again.
Please let me know if you have any questions or issues.
Thanks
John
- JinTuSep 03, 2021Star
JohnPeng wrote:The latest LM1200 release has been posted online. If your device's IMEI is ending with 0, 1, 2, 3 and 4, it can be upgraded now.
Thanks JohnPeng, my IMEI ends in 7 and I don't see the firmware available to update online, nor can I find it on Netgear's support site. Any projections with other IMEI's will be able to access the firmware update?
- JohnPengSep 03, 2021NETGEAR Expert
Hi All,
The release is open to all LM1200 devices now. You can do manual upgrade check and follow the on-screen instructions to have your device upgraded.
Thanks for your patience. Please let me know if you have any questions.
Regards
John
- GeneK7087Sep 21, 2021Aspirant
Could you please provide a link to the new firmware file that I can download manually as I can not find it on the website download page. Thanks.
- JohnPengSep 22, 2021NETGEAR Expert
The latest release has been posted online for OTA FW upgrade. You can do a manual FW upgrade check to have your device upgrdaed to the lates.
If you have any issue for upgrading your device, please let me know.
Thanks
