JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
JinTu
Sep 01, 2021Star
The end of August has come and gone with no indication of new firmware being available.
JohnPeng are there any revised projections on when the LM1200 firmware update will be released?
JohnPeng
Sep 02, 2021NETGEAR Expert
The latest LM1200 release has been posted online. If your device's IMEI is ending with 0, 1, 2, 3 and 4, it can be upgraded now.
Please do a factory reset after upgrage and clear browser cache to start over again.
Please let me know if you have any questions or issues.
Thanks
John
- JinTuSep 03, 2021Star
JohnPeng wrote:The latest LM1200 release has been posted online. If your device's IMEI is ending with 0, 1, 2, 3 and 4, it can be upgraded now.
Thanks JohnPeng, my IMEI ends in 7 and I don't see the firmware available to update online, nor can I find it on Netgear's support site. Any projections with other IMEI's will be able to access the firmware update?
- JohnPengSep 03, 2021NETGEAR Expert
Hi All,
The release is open to all LM1200 devices now. You can do manual upgrade check and follow the on-screen instructions to have your device upgraded.
Thanks for your patience. Please let me know if you have any questions.
Regards
John
- VinceBlackSep 06, 2021Aspirant
Hello, I am experiencing the same issue. My IMEI ends with a zero and I'm not seeing an update when I manually do a check. I also checked website and states "No Firmware not availble for this model". Please advise on getting the latest update. Thank you.
- GeneK7087Sep 21, 2021Aspirant
Could you please provide a link to the new firmware file that I can download manually as I can not find it on the website download page. Thanks.
- JohnPengSep 22, 2021NETGEAR Expert
The latest release has been posted online for OTA FW upgrade. You can do a manual FW upgrade check to have your device upgrdaed to the lates.
If you have any issue for upgrading your device, please let me know.
Thanks
- GeneK7087Sep 22, 2021Aspirant
I had the router connecting with the SIM from Verizon that I had from previous router. But since the port forwarding wasn't working, I tried to do the firmware update. The router would just fail trying to look for the FW update. No explanation in the message other than to try again later. Since I had already switched the router from bridge to router mode, I tried reseting the router to factory settings and was going to switch the IP version from v4v6 to just v4, however, after doing the factory reset the router would then no longer make a connection to Verizon. So I can not even attempt to have it try to look for the firmware update. Thus, I need a link so that I can manually download the file and upload it that way to the router. When I searched on the Netgear website for the firmware it says there is no update available. So again I ask, could please just post the direct link to the download so that I can manually download the firmware. Thanks!
