JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
JohnPeng
Sep 02, 2021NETGEAR Expert
The latest LM1200 release has been posted online. If your device's IMEI is ending with 0, 1, 2, 3 and 4, it can be upgraded now.
Please do a factory reset after upgrage and clear browser cache to start over again.
Please let me know if you have any questions or issues.
Thanks
John
JinTu
Sep 03, 2021Star
JohnPeng wrote:The latest LM1200 release has been posted online. If your device's IMEI is ending with 0, 1, 2, 3 and 4, it can be upgraded now.
Thanks JohnPeng, my IMEI ends in 7 and I don't see the firmware available to update online, nor can I find it on Netgear's support site. Any projections with other IMEI's will be able to access the firmware update?
- JohnPengSep 03, 2021NETGEAR Expert
Hi All,
The release is open to all LM1200 devices now. You can do manual upgrade check and follow the on-screen instructions to have your device upgraded.
Thanks for your patience. Please let me know if you have any questions.
Regards
John
- VinceBlackSep 06, 2021Aspirant
Hello, I am experiencing the same issue. My IMEI ends with a zero and I'm not seeing an update when I manually do a check. I also checked website and states "No Firmware not availble for this model". Please advise on getting the latest update. Thank you.
- JohnPengSep 06, 2021NETGEAR Expert
If you kept seeing Update Error, please do a factory reset and check for update again. The release has been posted online for all users.
Let me know if you still have the issue.
Regards
- JinTuSep 06, 2021Star
I was able to update the firmware online and performed a factory reset via the GUI afterwards, but it seems to have retained some, but not all of the previous settings (APN settings were reset, but network selection mode was still set to manual). That said, the original issue (repeatidly dropping the Ethernet link until the DHCP lease is force release/renewed) persists. Also, I am still unable to pass traffic via IPv6 despite being issued an IP address. I will try converting to router mode to see if anything behaves differently and will report back.
