JinTu
Aug 26, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
PeterG5000
Sep 22, 2021Tutor
Same problem.
I am plugging into WAN2 on UDMP.
LN1200 LAN light goes on and then off..
I plug LM1200 into my computer and it connects fine.
I have tried EVERYTHING I could think of. I disabled IPv6. I upgraded firmware. I plugged into WAN1. Nothing worked.
I need a LTE backup for my UDMP. This should have been EASY!!!!
Any help would be appreciated. I also have put in a support request. I hope I get some kind of response to this.
I believe this is a LM1200 issue and NOT the UDMP.
Thank You,
Pete G.
Pmolter13
Sep 22, 2021Aspirant
I am also having the same issues with the LM1200 on Verizon but with a Tplink router.
I was able to confirm with VZW that there should not be any issue connecting a DHCP router as the hotspot plan does not limit connections. I also have a support ticket open with Tplink to review the router logs showing the disconnect and reconnect cycling.
However, I even tried an older Actiontec router left over from my previous ISP and that had the same issues once I connected multiple devices. This only seems to occur if the modem is connected to a router or hub. If it's a direct 1:1 connection, be it game console, pc or laptop, it works fine.
- PeterG5000Sep 22, 2021Tutor
Thanks for checking with Verizon. So we have pretty much ruled out everythign but the LM1200. I wonder if anyone has tried the Nighthawk M1 Moble LTE hotspot MR1100-100NAS? We need Netgear to fix this issue or I have to send this back. We are using this as the backup Internet in the case there is an outage with our wired carrier.
- JohnPengSep 22, 2021NETGEAR Expert
Hi All,
For reporting the LM1200 dropping link issue when connecting with a router as client, please check the the device has been upgraded to the latest FW release:
App Version: NTG9X07C_20.06.09.00
PRI version: 04.19
If the issue still happens, please report the following information:
1. LM1200 is set as Router mode or Bridge Mode
2. Carrier Name
3. APN name
4. IP Type
5. Is LM1200 connecting to WAN backhaul
6. Router client brand and model
7. Broadband modem brand and model
Thanks
- JinTuSep 22, 2021Star
PRI version: 04.19
1. LM1200 is set as Router mode or Bridge Mode: both bridge mode and Router mode exhibit the same behavior.
2. Carrier Name: Verizon
3. APN name: VZWINTERNET
4. IP Type: IPV4V6 setting in APN. Both IPv4 and IPv6 IP addresses are issued once the connection stabilizes. The router interface is configured for DHCP for IPv4 and SLAAC for IPv6.
5. Is LM1200 connecting to WAN backhaul: WAN interface on the LM1200 is not connected. The LAN interface on the LM1200 is connected to the router. The LM1200 Advanced->Failover->Default Connection is set to Mobile Broadband only.
6. Router client brand and model: pfSense Plus 21.05.1 on Netgate XG-7100
7. Broadband modem brand and model: NA
