JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
JohnPeng
Sep 22, 2021NETGEAR Expert
Hi All,
For reporting the LM1200 dropping link issue when connecting with a router as client, please check the the device has been upgraded to the latest FW release:
App Version: NTG9X07C_20.06.09.00
PRI version: 04.19
If the issue still happens, please report the following information:
1. LM1200 is set as Router mode or Bridge Mode
2. Carrier Name
3. APN name
4. IP Type
5. Is LM1200 connecting to WAN backhaul
6. Router client brand and model
7. Broadband modem brand and model
Thanks
JinTu
Sep 22, 2021Star
PRI version: 04.19
1. LM1200 is set as Router mode or Bridge Mode: both bridge mode and Router mode exhibit the same behavior.
2. Carrier Name: Verizon
3. APN name: VZWINTERNET
4. IP Type: IPV4V6 setting in APN. Both IPv4 and IPv6 IP addresses are issued once the connection stabilizes. The router interface is configured for DHCP for IPv4 and SLAAC for IPv6.
5. Is LM1200 connecting to WAN backhaul: WAN interface on the LM1200 is not connected. The LAN interface on the LM1200 is connected to the router. The LM1200 Advanced->Failover->Default Connection is set to Mobile Broadband only.
6. Router client brand and model: pfSense Plus 21.05.1 on Netgate XG-7100
7. Broadband modem brand and model: NA
