JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
chibikegeek
Nov 17, 2021Aspirant
This is happening to me as well.
Dual NETGEAR 1200s > TP-Link Omada > TP-Link Archer A10.
The Details:
Firmware Version: EC25AFFDR07A09M4G
App Version: NTG9X07C_20.06.09.00 Web
App Version: LM1200-HDATA_03.03.103.201
Hardware Version: 1.0
View from the Omada attached.
Peaks correspond to LINK DOWN, valleys to +/- 30 from LINK UP
- JohnPengNov 17, 2021NETGEAR Expert
The Details:
Could you please confirm which carrier's SIM you are using, Verizon?
Thanks
- AaronWTCINov 19, 2021Aspirant
I am also having the same exact issue, works fine plugged into a laptop. As soon as i plug into my sonicwall or other routing devices it drops out. updated firmware, reset to default. Doesnt work in bridged or router mode.
I did just find if i plug the LM1200 into a TP link Archer 750 it works just fine. I can then plug my Sonicwall into it and it works through the lan fine. So there seems to be something going on with some kind of port security or buggy kind of issue on the port on the lm1200??
- chibikegeekNov 21, 2021Aspirant
I'm using two LM1200s, each with a different carrier SIM, load balanced using an Omada.
The two SIMs currently in use are a TMO SIM and a VZN SIM.
- JohnPengNov 21, 2021NETGEAR Expert
Thanks for the details. After we found the solution for the Verizon LTE drop connection drop issue, I would like to ask your help to verify the fix.
Regards
