JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
Serdar
Nov 24, 2021Aspirant
Having the same issue on Google Fi (which is actually T-Mobile, but a different APN).
- LM1200 is set as Router mode or Bridge Mode: Bridge Mode
- Carrier Name: Google Fi (on T-Mobile)
- APN name: h2g2
- IP Type: IPv4
- Is LM1200 connecting to WAN backhaul: No
- Router client brand and model: Netgate 7100 1U (pfSense Plus 21.05.1)
- Broadband modem brand and model: N/A (Fiber ONT)
Logs from pfSense:
Nov 21 01:01:55 pfsense kernel: e6000sw0port2: link state changed to DOWN Nov 21 01:02:17 pfsense kernel: e6000sw0port2: link state changed to UP Nov 21 02:50:06 pfsense kernel: e6000sw0port2: link state changed to DOWN Nov 21 02:50:28 pfsense kernel: e6000sw0port2: link state changed to UP Nov 21 05:14:39 pfsense kernel: e6000sw0port2: link state changed to DOWN Nov 21 05:15:01 pfsense kernel: e6000sw0port2: link state changed to UP Nov 21 07:02:51 pfsense kernel: e6000sw0port2: link state changed to DOWN Nov 21 07:03:13 pfsense kernel: e6000sw0port2: link state changed to UP
JinTu
Nov 25, 2021Star
Logs from pfSense:
I am seeing the same thing on Verizon with pfSense, but was able to temporarily work around it by manually releasing and relinquishing the DHCP lease, then forcing a renew. Sometimes it requires doing this a few times for it to work, but once the link stabilizes, it stays up.
