JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
txagg
Nov 27, 2021Aspirant
Add another one to the list. I just purchased this device and with my USG Pro the connection drops about every 2 - 3 minutes when in bridge mode and then comes back with a new IP after about 1 minute, making the the connection basically useless.
App Version: NTG9X07C_20.06.09.00 - Confirmed
PRI version: 04.19 - Confirmed
- Bridge Mode
- Verizon
- VZWINTERNET
- IPV4V6 in APN, IPV4 in router
- LM1200 LAN to USG Pro WAN1
- Ubiquiti Unifi Security Gateway Pro
- N/A
JohnPeng
Dec 02, 2021NETGEAR Expert
Please try enabling Keepalive and set the timer as 1 minutes and let me knwo whether this helps or not. If not, I will need your help to capture some logs for the team to check.
Thanks
- Bridge Mode
- Verizon
- VZWINTERNET
- N/A
- SerdarDec 03, 2021Aspirant
Looks like that did it, thank you! It's been fine for ~18 hours now since I enabled KeepAlive. If it happens again, I'll update.
