JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
NathanR2D2
Jun 15, 2022Aspirant
JohnPeng Any updates? My Orbi RBR50 keeps dropping internet connection after a few hours with the WAN port connected to my cable modem and Verizon for LTE. Any ETA on a new firmware release address? Failover also does not work properly.
JohnPeng
Jun 16, 2022NETGEAR Expert
As I just replied to another customer, this is not device issue. It is related to Verizon network. If you connect a computer to the ethernet port using the same Verizon SIM card, you will not see the issue. The issue only happens when your connect a router to ethernet port and the connection is released by the network, not by the device.
Thanks
- NathanR2D2Jun 16, 2022Aspirant@Jonhpeng
I placed the LM1200 in router mode and will monitor to see if it still drops the WAN IP after a few hours. The primary connection is my cable modem with LTE as failover.
