JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
alannn
Apr 04, 2023Aspirant
Any updates on this? It kind of seems like netgear/verizon are giving up on this issue.
The frustrating part about this is that my novatel T1114 was working fine until Verizon decided to block these routers because of their 3g changes. I purchased the LM1200 as I was told it was supported, and randomly after a power outage, my LM1200 will either flap the LAN while in bridged OR constantly disconnect/reconnect to the cellular while in router mode.
I have tried factory reset, multiple cables, multiple routers. The only thing that keeps it stable is connecting only a laptop.
The keep alive "work-around" does not work for me, I have tried 1 and 15 minutes and completely off.
- ilektranikApr 22, 2023Tutor
I get the LM1200 fitful 20 to 90 second reconnects in fail over with Verizon like everyone else.
But:
In 'Mobile Broadband only' the LM1200 works fine. With a half dozen hosts. Rock steady. But not if it failed over to Mobile Broadband:
Pull Wired Broadband WAN cable and LM1200 fails over to cellular.
LM1200 loses both Internet and LAN links several times doing so. (Reconnects.)
LM1200 then loses Internet and LAN links every 20 to 90 seconds. (Reconnects.)
No devices like VoIP adapters may register. (No time to do so.)
Browsing is next to impossible. (Once again time but if done quickly possible.)
Turn ‘Keepalive‘ off it reconnects.
Set connection to ‘Mobile Broadband Only’ it still reconnects.
Plug Wired Broadband WAN cable back in and Mobile Broadband starts
working fine!
With the Wired Broadband up and available!
Turn ‘Keepalive’ back on and after a couple link bobbles Mobile Broadband
works fine!
Through 'Keepalive' pings!
Select auto and LM1200 switches to wired fine.
Pull Wired Broadband WAN cable and the above starts again.
Work with me guys. There is a way to fix this I believe.
ilektranik
Or more succinctly:
Fail Wired Broadband by pulling cable.
When in Verizon Mobile Broadband repeated reset mode after failover:
Settings > Advanced > Failover > Mobile Broadband Only > Submit
Settings > General > Software and Reset > Restart > OK
Mobile Broadband now works continuously for multiple hosts after boot:
Wired Broadband still connected. Lights on LM1200 all green.
Tested for 1 hour on multiple devices. All good.
Then:
Settings > Advanced > Failover > Auto > Submit
Swaps to Wired Broadband pretty as you please.
How is this Verizon?
ilektranik
Instead of " Wired Broadband still connected." in above it should read "Reconnect Wired Broadband."
It seems this is not a multiple device on Verizon issue or any other Verizon issue. This is an LM1200 Firmware issue.
You lose not only Internet connectivity but LAN connectivity to the LM1200. Verizon cannot do that. The LM1200 can.
Not giving up yet.
ilektranik
