JinTu
Aug 25, 2021Star
LM1200 repeatedly dropping link
I recently purchased an LM1200-100NAS to serve as an LTE failover connection for my homelab and noticed a strange issue while setting up my pfSense-based router to use the LM1200 as a secondary WAN c...
greyace90
Mar 04, 2024Aspirant
I had it working for a bit, thinking either a firmware update or maybe Verizon fixed it. I had to reboot the modem to move a cable and since then, it went right back to not working. So I had to go back to double NAT. Well if you factor in the CGNAT, then triple NAT! I’m not thrilled but it’s the best I’ve got especially since it’s just for backup Internet.
- stuyboyMar 04, 2024Tutor
I'm in the same boat as just using this for backup, and remote access to a secondary location. Using some MVNOs and cheaper pay-as-you-go options for LTE (ie Tello), the cost is about the same as adding onto my VZ plan. Would have been nice to share the same data plan as my mobile, but probably not worth the trouble/cost at this point.
