g8rvet
May 30, 2022Initiate
LM1200 Upload speed on Ethernet Switch
Purchased a flat panel antenna and checked that it worked. Got good upload and download when connected directly to computer (through a punch down panel in my internet closet). Did final testing and checked it in location and mounted. Still great signal (around 18Mbps down and 12Mbps up). Changed to router mode and it worked well in router mode-same speeds. Then I hooked it up to unmanaged ethernet switch, the download drops to 7Mbps and the upload becomes unacceptable - like 0.2Mbps. This was with two TVs plugged in to the switch and off-nothing else is on. This is the exact setup I used with another broadband LTE modem. It worked fine until they went out of business. Seems like I am setting something up incorrectly as it works perfectly with the punch panel and computer alone. The switch is 100/1000 and less than a year old and was flawless 1 month ago.
an unmanaged switch really shouldn't be affecting anything.
It could be the tv's downloading something in the background.
Have you tested them separate? What I mean is just the LM1200---switch--->computer with nothing else connected?
- g8rvetInitiate
Thanks so much. That is what I thought. I did exactly that last night and found one of the antennas to the router was not fully engaged (TS9 is a crazy port - so easy to accidentally unplug).
